jerjwillelec
- Nevada, IA
- Master Electrician
LP pump: nameplate says 12 amp at 120 volt. 119-120 actual volts at pump under no load. Actual amperage while filling tanks 20-22 amp, sometimes up to 25 amp...voltage drops to 111+/- volt when filling. Since it was installed two(ish) years ago, it inconsistently trips breaker and or Allen Bradley P32 thermal overload. Thoughts on amperage differences from nameplate? My first thought is voltage drop/circuit distance.
Sent from my SM-G920R4 using Tapatalk
