Lighting
charlie
Indianapolis
Re: Lighting
I assume you are intending to say lumens per watt? You first, what do you think? After you answer, we will help. We are not in the business of just answering your test or homework question; however, we are here to help you. :D
Re: Lighting
Thanks Charlie,
I did mean to say per watt.
Mercury vapor should give you the most light per foot candles.
Thanks, Paul
tom baker
First Chief Moderator
Re: Lighting
Soory no, it certainly is not MV, HPS has twice the efficient than MV, And some of the new t-5's are better than HPS.
but the most efficient source in general use is low pressure sodium.
luke warmwater
Re: Lighting
Tom,
it's been so long since I've seen a Low Pressure Sodium fixture or lamp. I've known too much since then so they've been almost completly erased from memory :)
Todd
