Re: lighting strikes
It is nearly impossible for lightning to come through a transformer and into a building on the hot secondary conductors. I believe that most lightning enters the home, business, well motor, etc., through the neutral and or ground.
I have cut up many pole mounted distribution transformers to observe lightning damage, and in many cases, the damage can be seen as a small hole through the paper insulation within a few primary turns of the hv side or the neutral side, but never more than a few turns into the coil. There is just too much impedance in a transformer for lightning to go through it in any quantity.
Jim T
