LED Dimmers
Kopper
Lewisburg, Pennsylvania, USA
Electrical Contractor
I am looking for an LED dimmer that uses the reverse phase or ELV dimming technology. I have used the Lutron Ariadni various times with good success on certain LED bulbs. I used a different LED from Aspect LED, terrific light by the way, and now i need a toggle dimmer that uses ELV instead of MLV technology. I found plenty of ELV dimmers but none that are a toggle with the slider beside... :( any help would be greatly appreciated!
Pizza
Minnesota
Cooper TAL06P
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Very interesting that this dimmer claims to dim almost any situation. Not sure how it does all that
Single-Pole & 3-Way
300W Dimmable LED, Dimmable Compact Fluorescent (CFL)
600W Incandescent (INC)/Halogen (HAL), Dimmable Fluorescent (FLR), Magnetic Low-Voltage (MLV), Electronic Low-Voltage (ELV)
meetoomc
Lewisburg, PA US
I'm not sure either and I'm not sure that it does. I need to play with the adjustments more to see if it will actually work for a reverse phase LED... It does work to some degree but there is some low end flicker. Not just a nice solid dimming... Yet.
Sent from my XT1080 using Tapatalk
PHL
Minneapolis, MN
I have had experience with this dimmer. When using a oscilloscope this dimmer does not produce a reverse phase sign wave. I have never seen a dimmer that produces ELV Reverse phase dimming without a neutral connection for the dimmer. There is not a toggle dimmer that can produce a reverse phase sign wave from any of the major brands.
