kortelectric
- Rhinelander, Wisconsin, US
I need to provide power for a boat dock: De-icer (aerator) and boat lift. I plan to run power to a disconnect (20 amp, 120/240v) at the shoreline and then branch circuits to the de-icer and boat lift (20 amps each). There is a 300ft boardwalk (all new permanent pilings and treated lumber construction) from the high water mark that goes over a bog leading to the dock. I will need to bury a cable from the high water mark to the main distribution panel of the house about 100ft. I am also considering using a junction box every 100ft of the boardwalk (4) for use as a pull box, splice box and to tap for 120v receptacles for low voltage lights. Its about 400ft from the power source to the dock. What suggestions would you have?
