Junction box or sub panel; moving service panelboard.
five.five-six
california
the long and the short of it is that the POCO wants the service moved on a remodel I am working on. I was going to replace a zinsco 100 amp with a 200 amp Eaton. My question is: should I replace the zinsco with a can and use it as a junction box or replace it with a sub panel fed from the main panelboard?
user 100
texas
Either way is fine. The important thing here is that the zinsco is biting the dust. The bcs run from jb to new panel board is in a lot of cases cheaper, but that is going to depend alot on exactly how far the poco wants that service moved-where is the existing panel located?
growler
Atlanta,GA
If you can I would use the sub panel idea. If you don't extend the circuits then AFCI protection is not required.
user 100
texas
Very good point, growler. Alot of ahjs will provide some leeway in the afci reqs for reups, but if they don't then I agree: by all means go with that subpanel-less $$$.
