RL7
New member
- Landing NJ
Is it ok to run emt in a class 1 div2 room with proper barrier installed?
I'm running a low voltage t-stat with emt and comp steel fittings. I have a EYS eight inches from the block wall. From the EYS direct to the barrier.
I'm having trouble finding Intrinsically safe exceptions in the code.
Thank you in advance
