dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
I took a few courses on solar but Im still a little confused. Does anyone know of some clear pictures of PV grounding bonding for utility interactive systems?
I understand from the roof to the inverter but after the inverter where the disconnect switch is I always am confused about bonding the neutral or not in that disconnect.
I was hoping someone had pics for both line and load side taps dealing with the neutral.
Thanks in advance
Thanks in advance
