Thank you very much for all the replies they have been a good read for me...
-Gar...the clutches you have links to are similar to the one that is on the machine, I had a link to the MFG (which is Italian). I have searched the OEM drawings that I have and can't find it now
-Time is not important in the reaction of the clutch as it will be manually input for pre-stretch by the user. I am not integrating it with a pid loop or combining it with a load cell- or anything of that nature.
-The inductance of the clutch, I can't tell you as I can't find the part specifications and I dont have the equipment to measure it....... Like I said before I had the manufactures web page up and It had some of those clutches pictured as u have in your links but I was unable to narrow it to the clutch that was on the machine...
The power supply that I have can't be manipulated, it powers the PLC and all the sensors, I had wanted to use it to power the output of the device. I would have to purchase another PS (one that is programmable). The OEM cabinet is getting very tight beacuse of the drives and , terminal strips PLC and other components and I don't have allot of room left (before failure most stuff was all in the circuit board). - So a DC motor controller is a great Idea but I don't think I have the room... and it will add to the heat in the cabinet...not in need of a fan yet!
"If response time is not a major factor, then a reversed biased diode across the clutch could be used to eliminate a need for a sink capability. In this case a programmable voltage regulator solid-state device could control the voltage and therefore current to the clutch, or an emitter follower."
This sounds interesting to me but I dont have the knowledge to build it (component selection and wiring)?
I can also program the PLC to output 0-20ma if that simplifies things.
What would be most helpful is a component list of what it would take to build what you describe in the quote above.
-Taking a look at the remaining posts.
ptonsparky...can you provide a link to this device? A small dc Drive sounds promising to me if I can get a small one (din rail mount preferred)...Is that what the CLICK is?
Johnybob...Its a Unitronics PLC....I didn't pick it, my boss imposed it on me. Next time I will use ab. This PLC has been a PIMA!
yes the PLC probably cant drive it, I cant find in the plcs specifications the load that can be imposed on the outputs so I don't want to risk burning it up. once this thing is done and tested at my location it will be shipped to another location several states away and I dont want to have to go out there and work on it much less look like a fool because of undersight.
-AlemanThe link you posted looks promising, but i don't like it as a connector arrangement. (if it were DIN rail mount!)...Gar...does this look like it will work?
http://www.axiomatic.com/4-20ma-din-controller.pdf
Again the lasts posts have been most helpfull and I appreciate the time spent. Please follow up if you can and have a great X-Mas
