kcaj
This is a little late, but just for comparison sake, I have a 200A 120/240V service at my home. I am total electric except for my aux. wood burning furnace. I live in a very remote area that has frequent outages. I recently relocated my service from my house to my barn. I now feed the house as an out building. When I moved the service, I installed a 200A transfer switch so that I can transfer my entire load to generator power when needed. I use a little 5KW portable generator that has a 10hp gasoline air-cooled engine. (paid $649.00 for it 8 years ago, can buy it now for $549.00). When utility power fails, I first walk to my loadcenter and turn off all 2-pole branch breakers (hot-tub, dryer, water heater, oven, both A/C units). Then I turn off all 1-pole breakers that feed motorized loads (refrigerator, freezer, water pump, septic pump). Next, I fire up the generator, plug it in, and throw the transfer switch to "gen". After a couple of minutes letting the generator warm up by powering lights and TV (kids you know) then I turn on, one at a time, the 1-pole motor loads.
I cannot run my dryer (5500watts) or hot tub (17,000watts) with this unit. But I can select the other 2-pole breaker loads, one at a time only, as needed. We actually get by quite well this way. We have had one 4-day outage in the hot summer time and one 4-day outage in the dead of winter. The outdoor wood furnace makes heat and hot water with fractional hp motors. The winter outage was easy. Only inconvenices were fueling/maintaining the generator and we had to make a couple of trips to the laundromat to dry clothes. The summer outage was a little uncomfortable as I could only run our smallest A/C unit part of the time.
Sorry for the long post, but I thought you might like to hear the experiences of a long-time generator user. I am convinced that a small generator can usually supply 90-95% of the needs of the average household. I am able to run about 18-20 hours on a 5 gallon tank of fuel. Largers generators will burn much more without any additional load unless you go diesel!
Hope you find this helpful!
