Re: hi pot testing
Jerry is the requirement for a megger insulation test or hi-pot. 2 different animals .?
Megger voltage is 1000 volts or lower and hi pot is 5,000 volts and higher. Also hi-pot can break a pinhole in otherwise good cable if there is a weak spot and tracking can then occur and cause leakage failures .Just curious
[ March 12, 2004, 08:03 PM: Message edited by: stew ]
