inspector23
- Temecula, CA
I have done two interviews lately, and both asked the same question -
"What is the difference between grounding and bonding?"
I am searching for a short (under one minute) explanation that would convey the difference. I believe the reason for the short answer is that the more clearly you understand the situation, the more concise and targeted you can make the answer.
There seems to be so much BS that floats around on this subject, it makes it hard to give a short, concise answer to a question I admittedly find difficult to answer in such a short amount of time.
Any ideas/suggestions/help?
Thanks -
Mike
Thanks -
Mike
