Re: Grounding Electrode Enclosure
Yes it would be a violation as the metallic conduit has to be continuous. the purpose of bonding it at each end is to prevent an impedance choke from being set up. Once you understand why, you know how or how not to. if the pvc is in the middle you might as well not bond each end.
