electrofelon
- Cherry Valley NY, Seattle, WA
250.64(c) states that the GEC connot be spliced except by exothermic welding or irreversible compression connectors. The exception also states that sections of busbars may be connected together to to form a GEC. I am unclear on two things. First, where GEC taps meet the GEC, must those connections also be welded or irreversible or is, say, a setscrew splice block ok. Irreverible connection may be implied by 250.64(C) since the whole assebly, tap and all, could be considered the GEC, however in the handbook they specifically differentiate between the taps and the GEC in the picture.
Secondly, regarding the exception to 250.64(C), does this mean one can only extend a bus bar in the equipment where the GEC is to terminate but not use a buss bar in a j-box as a spice? Thanks, Ethan.
