edwardcruz
New member
I have a question regarding the proper grounding of 2 disconnects to the meter can in a residential application.
Currently I have an existing 200amp disc. being fed by a 400amp (320 Cont.) meter can. The ground wire to the is coming from 2 ground rods 6 feet apart where it first lands on the nuetral bonding lug of the meter can. It continues through unbroken to a double lug mounted on the ground bolt inside the meter can. The other hole of the 2 hole ground lug has the ground wire from the existing disconnect panel.
My question to you is, can I simply install the new disconnect ground to the same hole of the 2 hole lug that the first disconnect ground is connected to? Right now I have mounted the hots and nuetral to the new double lugs installed on the respective hots and neutrals of the meter(both disc. are fed by the 2 hole lugs mounted on the load side of the meter).
