Grounding 208 Y pri.240 Delta sec. transformer
ddekruyf
New member
We are installing a 208 volt Y pri to 240 delta sec. to feed a single machine. There is some disscussion on what to do with X\O on the primary. What does NEC require?
augie47
Tennessee
Re: Grounding 208 Y pri.240 Delta sec. transformer
act like its not there
infinity
New Jersey
Journeyman Electrician
Just wondering how you'll ground the Delta secondary of this transformer?
LarryFine
Henrico County, VA
Electrical Contractor
Augie, are you saying that the primary neutral should not be run back to the supplying-panel's neutral?
Why not? :confused:
iwire
Massachusetts
Larry that is exactly what he is saying.
It is unneeded and under certain circumstances like a blown fuse on one of the ungrounded primarys it can burn up.
LarryFine
Henrico County, VA
So it's more like an ungrounded delta?
iwire
Massachusetts
I am guessing that this transformer is actually designed to be used as a 240 delta primary with a 208Y/120 secondary. I am also guessing they plan to use it backward which may be fine.
Used in this way the the XO terminal has no purpose.
LarryFine
Henrico County, VA
It seems that any imbalance on the delta secondary would swing the primary's X0 point away from zero volts to ground, resulting in unbalanced voltages among the three primary windings.
