grandpapastu
Problem:
120/240VAC 200A Single Phase residential service.
Completely severed and disconnected neutral at utility pole supplying the overhead service drop.
Phase conductors energized.
Question:
Would a main service disconnect GFCI circuit breaker interupt and disconnect the service to the house in the case of a disconnected or loose neutral?
On further review I conclude no. (Help)?
Also, I do not fully understand technical design and workings of a TWO POLE GFCI CB.
First thought is:
since I do not believe that a GFCI CB will do the trick, I need a Neutral Fault function available in the main CB whether the main disconnect CB is a GFCI CB or not.
Question:
First thought is:
