Re: Ground rod wire in meter base
Originally posted by hurk27:
To add to that Charlie, The first line of defense from lightning should always be outside of a building. The meter fitting is about as good a place as any to do this connection. Remember the lightning strike current should be directed to the outside not inside then outside.
Wouldn't that be "from the outside(sky) inside(water pipe)" as opposed to "from the outside(sky) to inside(MDP) to inside(water pipe)"?
Eventually, the goal of the system during a lightning strike seems to be to drive it inside, toward the water line.
Therefore, does it matter? Honestly, I've not dealt personally with a sticken house.
