I have 3000 amps, 277/480V MAIN SWBD located outside and feeding two buildings (building #1 & #2). SWBD have two main disconnects (one for each building), 1200A & 1600A and both have ground fault protection.
Building #1 has a 1200A, 277/480 Distribution panel with a 1200A main disconnect.
Question: Does the 1200A main disconnect in building #1 required to have GFI protection even though the feeder to this building already protected by GFI at the main SWBD?
It would seem that GFI protection for that building at the main SWBD located outside is adequate. Any comments?
