That is what a good circuit tester will do like a Sure Test.Originally posted by bennie:
I would apply a load, with an ammeter, across the line and neutral, then switch to the ground conductor. The ammeter should read the same.
Bennie: I agree to an extent, meaning that I as an inspector cannot require you as the installer to follow directions unless it is a listing requirement. However, you as the installer have an obligation to follow the manufacturer's requirements.Originally posted by bennie:
Manufacturers instructions are not enforceable unless the listing instructions make them mandatory to implement or observe.
