tsherrod
- United States
I have a customer who has had recurring issues with a light in her living room. The only erratic behavior I can find after addressing a few potential issues is continual voltage (12v) coming from the switch when it is turned off. The light is wired on a switch loop. Power comes to the fixture and a 3-wire cable (flex) is run from fixture to switch. With the switch on, I get 120v at fixture. With it off I am still getting 12v even after changing the switches. I assume the living room originally had a fan because of the 3-wire run and the double gang box. She only has a light fixture. Although I don't get continuity between the red and black conductors, when one of them is connected to power the other is getting some power even though the red wire is capped at both ends. Would this mean there is likely a knick in black and red wires somewhere between lighting outlet and switch box that is causing power to jump between them? I don't suppose it would cause a short because the unused wiring isn't connected to anything. If so, would the inability of the switch to completely cut voltage affect the operation of the light after an extended period of time, even it if it only 12 volts? Hope that made sense, it was a little harder to explain than I was expecting.
