Postonbones
- New Hampshire
- Electronic Repair Tech III/Electrician
A homeowner has a service disconnect mounted on a pole near the road ( meter socket and main breaker). The feeder to the sub panel is about 250feet, four wire. The sub panel is a main breaker panel ( not a main lug). Does the code allow an inter-lock to be used on the sub-panel? Once the sub panel main is off the L1/L2 are disconnected from energizing the utility lines. Or is a transfer switch needed for this type of install? Looking for some advice. Thank you.
