sparky 134
- Joliet, IL
i am doing a job ( restaurant ) that has a MDP ( main distribution panel ) feeding several smaller panels throughout the job. the raceway is RGC above ground and PVC underground. the print specified the size of the grounding conductor to be pulled to each panel but the owner of the shop says the largest grounding conductor needed is #6. i think the conductor should be sized according to 250.122. who is correct ?
thanks
thanks
