Quite often I find we are installing solar systems on multiple roof faces. For example I am working on a job with both East & West facing arrays. I would like to know more about using EMT as a sleeve to protect the PV wire from damage. Example is running PV wire over a ridge cap in a short EMT sleeve from the west roof to the east roof and then run both east and west array circuits in free air into a wiring transition box at the far end of the east array to switch to THWN-2. Is there a limit to how long a sleeve can be? What is the best way to ground the sleeve? Do I need to run an EGC through the sleeve with the PV wire or can I run my bare copper array EGC outside of the sleeve and use a bonding bushing on the end of the sleeve to bond the sleeve to ground? Technically by code the EMT can act as an EGC. Alternatively, can I run the bare copper racking/array EGC through the sleeve with the PV wire while still using a bonding bushing to bond the EMT to ground? I understand that an EGC must be run inside a raceway with the ungrounded conductors. The way I understand the definition of a sleeve is it doesn't have boxes on either end and one would use a pull bushing that has a piece of plastic to protect the wire from the sharp ends of the EMT. If possible I would like to prevent having to set two boxes with strain reliefs on both ends of the EMT running over the ridge cap. Is this doable or is this a code violation? Is there somewhere in the NEC that provides definitions & requirements for sleeves?
