Re: emt conduit
I would like to give my reply to the question, "is EMT acceptable as the equipment grounding conductor" and the answer was yes, referring to Section 250.118.
Now, I would like to give my opinion on this subject. Where I worked for many years, we always used the conduit, etc for the equipment grounding conductor. But let me tell you the objections that I have on this subject. Through my experience, many times we would lose the continuity of the grounding conductor, because of the coupling becoming corroded, therefore having a high resistance in ohms, or sometimes the conduit would be broken, therefore, losing your EGC.We changed our policy where I worked. They now always have a EGC pulled inside of the conduit, or emt, etc.
I certainly would hope that all companies would follow this procedure. In fact I feel that this would be a good change for the 2008 NEC.
