Re: electrical code requirement concerning remtal property
Your best bet is to call your local AHJ (Authority Having Jurisdiction). That may be your building, electrical, or housing dept. There may also be FHA, HUD, other federal (or state) jurisdictions.
At bare minimum in my town you'd have to install smokes (battery operated) in each sleeping bedroom, and in the hallway(s) outside the bedrooms. It's usually part of the escrow punch list along with broken windows, deadbolts, solid front door, fireplace spark arresters, etc.
If certain remodeling or redecorating is done there may be a requirement by the AHJ for 120-volt/battery-backup smokes. They may have to be interconnected. Your mileage will vary. Check with the AHJ.
In Berkeley, CA (a college town) a few years ago several students were killed in a private house. They rented rooms. There was no local requirement for rental rooms to have smoke detectors (it was a very old home). There is now a LOCAL ordinance that if you rent out rooms (or your whole place) that you have to add smoke detectors. The moral of this story: A six-pack of smokes is less than $70. Install them even if not required. Educate the tenants on their importance and make sure they replace the batteries once a year (and that they don't remove the batteries). Or, hardwire them in. Either way, it's good/cheap insurance against somebody getting hurt or dead. Make sure they have easy egress too in case of fire.
[ October 30, 2003, 01:51 PM: Message edited by: awwt ]
