- Bremerton, Washington
Any recommendations on a Diversi Bit? Geenlee has diversi bit 941 kit for about $84.00. I've not used on before, am drill top and bottom plates from a wall opening - in a resi rewire
Or you can use the drill bit to push a loop of pull rope through the top hole and then hook it from below with a snake.Drop from attic to basement by measuring walls from landmarks such as duct and plumbing.
get the two holes perfectly in line and drop from top hole through bottom hole.
Works well if you have a big enough hole like 1-1/4"
I only use it once in a while, for that one hole you just can't get any other way.
resi rewire, I wire plugs from basement, lights and smokes from attic. That presumes one floor unfinished below.
