DCFIT
- Las Vegas , Nevada
installing PV Systems Require an A/C disconnect is it reqired to have a disconnect on the D/C side coming from thr inverter?
Sorry to perhaps be pedantic, but although the wiring may go from the inverter up to the panels, the "DC" is normally considered to be traveling in the direction of the power, namely from panels to inverter. This is particularly important if you use a DC breaker as the disconnect since those are not always symmetric in terms of polarity and current direction.well ive been installing an A/C disconnect . would it be best to install a second one between my inverter and my solar panels? thanks for the response. and yes my dc is coming from inverter up to my panels
