ctrane
- Jacksonville, Florida
Suppose Panel A feeds Panel B, and the voltage is 208/120/3 Phase, Y-Connected. Now, if you send the three phases plus neutral to feed Panel B, and Panel B is mostly made up of 120 non-linear circuits, does the neutral count as a conductor? Must the wire in the conduit feeding Panel B de-rated? Or, does the de-rate only happen when you have more than three "going in the same direction"? Meaning, the neutral current is traveling in opposite direction of the phase conductors.
