Yes.Can I run DC source circuit conductors, in EMT, inside wall?
Maybe it changes the nitty gritty of some code requirements (technically that's not a source circuit anymore), but you can still do it.Does it change things if it's optimizers?
Doesn't change anything.How about rapid shut down?
Doesn't change anything.DC Disco on roof?
The NEC does not require it of PV source circuits but your AHJ might. But 690.15(C) says that if you combine strings on a roof you must have a disco up there.thx
To be clear: no provisions must be made to de-energize the conductors if inside wall?
