I've read about 50 posts on grounding, and everyone seems to have a diffrent answer, I'm getting really confused. Here goes.
RG-6 lines from dish to CATV pannel in basement.
Ground line run from dish (Through Walls) to a cold water pipe, and bonded. (to ground dish)
Another ground line run from inside the low volt box (where the RG-6 Ground block will be located) to another cold water pipe, or the grounded electrical subpannel box.
