shunt trip
New member
I am an electrician working in Iraq and my question pertains to grounding multiple living containers. I would like to know if it is against NEC to use a ground wire from the panel of one trailer to the frame, then daisy chain two other trailers under the same screw to a common ground rod at the third trailer.
