I have 15 customer event relays that a customer wants to have rated at 5A each. I will be connecting the relays to the output of a PLC, and the customer will then connect to the relay outputs.
What protection do I have to supply the customer? Are voltage/current ratings and yellow #16AWG wiring enough? The yellow wiring is meant to indicate that the conductors could still be live even with the equipment disconnected from the power supply...
