sanders11
- Louisville, KY
I have an application where there is a conduit run between an Class I Div. I XP enclosure and an intrinsically safe device. The XP enclosure has an appropriate XP seal-off. Can I use a liquidtite flexible metal conduit to run to the intrinsically safe device?
I know that article 50.10 (2) lists only flexible metal conduit as the only option, but does it still apply when the circuit is intrinsically safe and has the appropriate seal-off on the other end of the conduit run?
