Re: Cable Suitable for Mine
Depending on the application, this is not typically an NEC issue. See Section 90(B)(2).
Having said that, again depending on the application, there are several cable constructions that are suitable for mines.
Since I do not know the application(s) you have in mind, I would suggest contacting the major cable manufactures directly. Most of them will have no problem pointing you in the right direction.
Edit Corrected spelling errors
[ February 10, 2006, 12:36 PM: Message edited by: rbalex ]
