I just powered up a new house and have been finishing up a few things. Yesterday when I walked by the panel I heard one of the (3) Arc fault breakers buzzing (not loud). This breaker supplies the lighting for 3 bedrooms. I turned it off, reset it and it stopped for a while. Later on I noticed it buzzing again, so I pulled the cover, disconnected it and check for continuity between the neutral, ground and hot. Nothing, all clear.
I swapped conductors with another circuit and turned it back on, and it started buzzing again (same breaker), which leads me to believe that the breaker is defective. Later on I felt of the breaker and it was warm. This is a Seimens 20A single pole, and the load that I had turned on was 1 light and 3 ceiling fan motors, I calculate about 8 amps load. I pulled the breaker to look at the lug and it looked good and felt snug. The breaker tests and resets OK. Anyone else ever have this problem? Any ideas?
steve
steve
