Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
Code uploaded. Is this to suggest that you cannot cut wires inside LBS or RIGHT BEND metalic elbows and connect wire nut as you would with a box or is code saying not to be done only in specific type LBS such as capped elbows (which I have not come across)?
