Re: bidding outlet replacements etc
stew: sorry if you thought i was giving you a price or are you asking me if I think that the extrapolated figure you quoted is what i was saying or that the extrapolated rate was too high. At bid, i never figured that i would be able to actually come close to what I figure for time, minimum of double time by the end of job, parts runs,bid, first visit, yada yada.
AND man what do you do with that unpaid time for 6.5 hour days. clean the truck, shoot some hoops, kick back, or maybe you are organized enough to have a few short jobs as back up, BUT if you aren't that together, you aren't going to get a full day's pay. Worked with another one shop contractor who said that at best he averaged only 6 hours actual work in most days. He said that he bid that for a full day, and it averaged out.
I don't think $400 a day is high at all, unless you are in a depressed area. There are a lot of real expenses (and if you noted, I put general quality replacement parts in that figure, but not gfi's or 3/4 ways). I dislike the idea of overcharging, but I think that what I was saying was that my figure was low. I did not put anything but straightforward sp sw. and duplex in the 3 to 5 min range. I think a stove outlet with stove in place is about 35 min. min. with cleanup and floor protection without any electrical problems. Some old 3 and 4 ways had different configs, and you need to test to make sure that they work, definitely out of the 3 to 5 average. Gfis barely fit in some old boxes. they take me about 10 min apiece when I'm moving along, assuming nothing unforeseen.
you can't bid old work as piece work at low rates, it doesn't work in the long run.
paul
