Re: Balanced 120VAC or 60VAC to ground?
Thanks for the input,
The situation goes like this...
A fella asked me to rough out some lighting, sounded simple enough...The lighting is in his brand new recording studio. Another electrician had already roughed in the power. He seems to have done a very good job, but the the thought did cross my mind that a typical residential power layout might not be exactly what this guy was looking for. So I did a little research, and asked him if his previous electrician had given any consideration to potential ground noise problems. The answer was no. So to date there is no problem, as the studio is not operational yet.
However, if it becomes a problem, I was exploring options on this guy's behalf. I appreciate the link, it was actually a tech release from an engineer from equi-tech that led me to post the question. Basically i was just curious how field proven the method was/is. Also, this guy seems a little bit old-school, and I want to discourage him from simply 'lifting' the ground.
