I am looking to purchase a arc flash suit.
Any recommendation, Dos and Don'ts will be appreciated.
I usually don't work on large energized switch gears but do want to have a suit just in case I may need one.
Thanks
keep in mind that for the most part you can't work on live equipment even with an arc flash suit.
Neither of those cases would appear to fit the exceptions.
what about if one owns the company or is an officer of the corporation, then who says I cant work hot?
Then what is the purpose of the arc flash suit if you can not work it energized??
Why do they even sell the suits?
I am sure they are situations that you have to work it energized.
Usually the people paying you such as general contractors and business owners that relize they can also be fined.
The right answer is that you should have several levels of PPE that allow you to work most comfortably while still being adequately protected: E.g. at 15cal of incident energy, I would much rather wear a long-sleeve AR shirt and face-shield as opposed to the full 40cal moon-suit.
That said, very often there has been no flash hazard analysis performed and folks are basically guessing at how dangerous equipment may be. So you want the best protection you can buy:
1) Get a 40cal suit that is the full-length coat-style. This is much easier to put on than the jacket-and-pants and also lot more comfortable.
2) Get a hood with a built in blower. The face plate will fog up otherwise making it impossible to see.
3) If you only work with 480V max, get properly sized class 00 500V gloves and leathers. These will give you the best possible dexterity.
The goal is to make this stuff as easy to use as possible so that you do use it when needed. If you cheap out on it and hate wearing it, then you won't, and that is money wasted and extra risk incurred.
Also it has to be said: I see a lot of "DANGEROUS" labels on 480V gear where no PPE exists that will keep you safe. You can still be killed while wearing a complete 40cal suit in the wrong circumstances.
I don't know how that PPE is certified, but I have to assume that is a consideration addressed during design and testing: Arc-resistant gear that still allowed you to be burned obviously wouldn't have much value.I would not want just the full length coat as the blast could blow up and under the coat...
