sparks27
- Portland, Oregon
hey guys, new guy here. I have a homeowner wanting to change the al. wire in his home. I'm looking for alternatives.I've spliced copper onto the al. ends and put noalox on. is there other things I can do?
Originally posted by shelco:
In my area and what I found when doing research is that the purple 65 are no longer accepted as there are to many documented failures.
This is absolutely Incorrect.
Do a search on this site for topics on the subject.
AMP is trying to do a good job at marketing their competitors products as junk.
If they want to replace the wiring with copper why try to find alternatives. That is the best way to go. Not only will they get rid of the aluminum, they will also get wiring to current code which will mean more circuits and more receptacles. Just a better installation overall.Originally posted by sparks27:
Can you provide some sort of link for verification of your claim?Originally posted by shelco:
...purple 65 are no longer accepted as there are to many documented failures.
I dunno what you read, but I read:Originally posted by luke warmwater:
But the one issue I see with the Purple Twisters is that they are rated for (1)CU to (1)AL only.
This can be very hard to accomplish, and may require quite a few 'Nuts' in the box.
