Advice about 2-pole vs 3-pole AC disconnect for large system
I am putting together my first solar system and need some advice. The diagram attached shows a blue line down the middle - all items to the left have already been purchased, and to the right are items I am not 100% sure of, in particular, the Square-D 200AMP Disconnect (D324NRB). I read at http://www.thesolarplanner.com/steps_page8.html the following:
"For the AC disconnect itself, you would choose a 30-amp model, 2-pole product. If your inverter is transformerless, and you decide to buy a fusible AC disconnect, you'll need to get a 3-pole model in order fuse the neutral conductor in the circuit, since it won't be grounded."
The two inverters for my system are SolarEdqe "Transform-less SolarEdge SE11400A-US 11.52kW, 240V, 60Hz Continuous Output Current 48A". Being that they are transformless, and the advice above, I think I should use 3 fuses for Ll, L2 AND Neutral... Is that correct? Any advice on this or anything else in my drawing would be greatly appreciated.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I will tell you this that you never fuse the neutral conductor
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
