Re: A few questions
Originally posted by gsurface:
I am an instructor for a new electrical program and though I have experience in the residential wiring, my main background is Engineering (Degree in Electrical Engineering). I just have a few questions that have crossed my mind. Here they go and hopefully I can have them answered .
Welcome and you came to the right place, all your questions can be answered by the various members here.
I am going to let you know you are bound to get some grief about being an instructor for an electrical program and needing answers to some of these questions.
I also wonder what the requirements are to be obtain a Degree in Electrical Engineering?
Some short answers, others will surly elaborate.
1. What are advantages and disadvantages between single-and three-phase supply systems?
Three phase is more cost efective.
As an example a 10 HP single phase motor draws 55 amps @ 208 volts.
A 10 HP three phase motor draws 30 amps @ 208 volts.
This results in smaller conductors, raceways, disconnects and ultimately a smaller service size.
Keep in mind the motor still uses about the same energy but it is now dived by 3 conductors not two.
There are also other advantages to 3 phase motors and systems.
2. What are the differences between Wye and Delta connections? Why use one over the other?
Do you need a neutral or not?
There is more to it than just that and I am sure others will bring them up.
3. In a 3-phase motor, how come it has no neutral connected to it? Doesn't the current need to return somehow?
This is the same as asking why a diesel car does not need gas.
If I had a 240 volt single phase motor would you expect a neutral was needed?
This is hard to explain without graphics hopefully someone will post a graphic.
But a neutral is not a 'return' conductor.
What exactly will you be teaching?
I think it's great your trying to find the answers but it in my opinion you are not ready to teach about commercial electrical systems.
Good luck and I hope you can take some ribbing, let the ribbing slid by as in between some ribbing you can get some very concise answers.
Bob
[ February 12, 2005, 06:12 AM: Message edited by: iwire ]
