rickgomes26
Hi All
I have a pv contractor who has installed a ¾” LFNC conduit inside an (E) 2” PVC raceway with the (E) feeder from the service equipment(located at a detached structure) to the primary dwelling. The LFNC contains the PV output circuit conductors, and they used the LFNC as a barrier to comply with 690.31(B). I’m attaching a couple of very poor photos but its all I’ve got for now. Please see the questions below…
- Can you run LFNC in a PVC raceway?
- Can you use LFNC as a barrier to separate PV output conductors from other non-pv system conductors?
- Would I have to consider the LFNC when calculating raceway/conductor fill in the (E) PVC raceway?
- Can I the new LFNC raceway be pulled through a conduit that already contains conductors?(they did it, so the question is about code compliance)
- Would the LFNC be required to be properly terminated where it enters and exits the panelboard it is being routed through? (keep in mind they need the barrier in the panelboard too)
- Anything else I might have missed?
