kda3310
- Dry Prong, Louisiana
I have hooked up a GFCI breaker before but, not a 240 GFCI breaker. The house has a 50 amp GFCI disconnect already there with two legs of hot, neutral and grounding. Here is my problem. The hot tub is single phase 240 with a grounding bar. No neutral. So that's how I hooked it up. No neutral running to the breaker. I turned it on and it works. Is the occupants safe with out having something hooked to the neutral on the GFCI breaker to read the unbalanced load?
