I have a small commercial building that has 120/240 service drop coming to the back corner. I will have a 320 amp 2 position meter feeding 2 200 amp MBP's. 1 is directly behind meter and the other will be ran on exterior 50' to the other MBP. The water meter is located in the front of building. I've always had my disconnects built directly into the enclosure so there's no doubt size/where my GEC goes and where I come off for my rod. Question is how do I run my GEC from my water meter? Home run to each panel, to only 1, to 1 then interconnect the 2, use building steal as jumper? Ground rod at each panel? Any options and or answers greatly appreciated! 2014 NEC Thanks
Sent from my SM-N910T using Tapatalk
