wwhitney
- Berkeley, CA
- Retired
Does the phrase "distribution equipment . . . capable of supplying multiple branch circuits or feeders, or both" apply only to equipment that can contain OCPD?
Say you had a bussed gutter with 4 connections per bus (skipping over the case of 3 connections, as that does not allow for both multiple power source connections and multiple feeder connections). Is it subject to (2020) 705.12(B)?
If not, presumably instead a 6 position single phase MLO panelboard, with (3) sets of feed-thru lugs in the 6 positions, would be subject to 705.12(B). Since it is more "capable", because the feed-thru lugs could be replaced with OCPD?
Lastly, consider the Tesla Gateway 2 (an MID). It has busses, and those busses have 4 connections each (2 on the line side of the contactor, 2 on the load side of the contactor). Ignore the optional internal panelboard for the moment. Is it "distribution equipment . . . capable of supplying multiple branch circuits or feeders, or both"?
Cheers, Wayne
Cheers, Wayne
