I am wiring a 208V Whirpool Tub with two hot legs and one ground. Back at the panel I am using a 2-Pole GFCI Breaker. It is my understanding that I will connect the two hot legs to the breaker and connect the white pigtail to the neutral bus. This will leave the neutral connection on the breaker open. First question: is this the correct installation? Second question: could someone explain what would happen if I connected a neutral wire from the neutral connection to the neutral bus?
Thanks,
David - St. Louis
Thanks,
David - St. Louis
