Happy New Year All.
We are involved with a project designed by a consulting engineer that has a 1600 Amp 480/277 VAC 3-phase 4-wire Y utility service. From the utility transformer to the 1600 Amp Ground Fault Protection Main Circuit Breaker 4 sets of 4-500 MCM are installed in four isolated phase conduits. The utility neutral is connected to the system grounding electrodes and bonded to the ground conductor in the 1600 Amp Main Circuit Breaker section. The utility service is grounded as a separately derived service. From the load side of the Main Circuit Breaker, the same size and number of conductors are used to power the normal side of a 1600 Amp 3-Pole Automatic Transfer Switch. The neutral conductor from the Main Circuit Breaker connected to a non switched pole (solid busbar) in the 3-pole ATS. The load of the ATS feeds a 1200 Amp MLO panel that has a 1200 Amp circuit breaker with other breakers under 1000 Amps. There is a 25 kVA 480-120/240 VAC step down transformer for all of the single-phase and low voltage 120/240 VAC loads powered from the load of the ATS. All of the 480 VAC loads are three-phase. Does this 1200 Amp branch circuit breaker in the distribution panelboard need to be GFP? I am under the impression that since the 2014 code change, this branch circuit breaker also needs to be GFP.
This project also has a 450 kW emergency generator with a generator mounted 800 Amp non-GFP circuit breaker installed on the unit. . The engineer's drawings call for two sets of 3-500 MCM three-phase conductors and a 1/0 ground wire in two 4" conduits to be installed from the emergency generator to the ATS, without a neutral wire. My understanding is with a three-pole ATS the neutral of the emergency generator must be isolated from the frame at the emergency generator, and the wiring should not be treated as a separately derived service. I believe this presents an issue as without the neutral conductor the only path for a ground fault to return to the emergency generator when it is supply power to the load would be over the ground conductor which is not connected to the emergency generator neutral. This ground fault would eventually return to the utility transformer source. I feel this would cause the GFP of the Main Circuit Breaker to nuisance trip and the generator circuit breaker may not open on a ground fault.
Please comment with your thoughts.
Thanks in advance.
Thanks in advance.
