ISMAEL VEGA
- Bayam?n, Puerto Rico
[FONT="]Hi all:[/FONT]
[FONT="]I know there are several ways to ground the sheath on 15KVunderground systems. I know that many utilities use what is called singlepoint grounding. In this option, the cable sheaths are supposed to bejoined together and to ground in one end and on the other end, they're supposedto be connected to ground individually through a Sheath Voltage Limiter. In this option, a ground continuity conductor is needed to connect bothends. What I have saw is that utilities ask to solidly ground the sheatsat both ends and also to run the ground continuity conductor. This willcreate current loops that generates heat around the cable which limits thecapacity of the cable. Do utilities take this into account or does thiscurrent around the cable is negligible?[/FONT]
[FONT="]I'll appreciate your explanation.[/FONT]
[FONT="]Ismael[/FONT]
